Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 08-24-2023, 05:46 PM
  #701
Skunkwrks
Skunkwrks's Avatar
Talking
Len I fly at 3400 feet above sea level so compared to a 140-142 it's only 14.5 % more thrust, and i won't fly my jets like they were stolen.
The pro recommends a 180-220, but i have a 240 in mine and yes, if I point to the sky, it's gone only my eyesight is the limiting factor.
I fly my Rebel Pro at 1/2 to 2/3 throttle very, very rarely is it opened up. In a ten and half minute flight, I burn 4.5 liter from a six liter tank and have 1.5 liter left in the tank...yes hard to believe.
My 166 needed a home in a sister Rebel 2m plane.
It's always good to have extra thrust when you need it!
Old 08-24-2023, 06:09 PM
  #702
wojtek
My Feedback: (73)
wojtek's Avatar
I fly at around 3K feet and a 140 is the most i would put in this plane. ... Lets me fly it like I stole it, and landings slow down ok, but i'm using almost 90deg flaps. 90 del vertical accelerating take offs with full fuel too .. , and I rarely ever go full throttle. the plane is too delicate ( when compared to something like an Ultra Flash, or Bolt)
Just my opinion, and i'm usually one to severely over power everything and any thing 😁
Old 08-25-2023, 01:38 AM
  #703
Dave Wilshere
Originally Posted by Skunkwrks
Tom, you only lose telemetry if the Rex7 loses signal then the Rec3 steps seamlessly and it is only of tenths of a second.
Harry doesn't prefer clones but in noise signal-filled areas it's the best bet to maintain signal to aircraft.
Watch Jonathan's latest video of radio testing, i was here to help get the data you will be surprised.
Most pointless test ever. Completely unrelated to how stuff is used!
The following 3 users liked this post by Dave Wilshere:
David J Ruskin (08-25-2023), Kenrico (08-25-2023), Mach1 (08-26-2023)
Old 08-26-2023, 10:39 AM
  #704
Skunkwrks
Skunkwrks's Avatar
Unhappy
Each to their own, its easy to pick up stones and throw them, isn't Dave.
No one else has even done a test like this so if you can do a better test all the power to ya.
Seems we do our range test on the ground, correct, so your point is moot.
Sure makes you think which is the point of it . Every radio experienced the same test and a few dark horses did extremely well.
The Powerbox head guy asked if the video could be taken down....................... hum......guess they should have providea better Rec than what they shipped. Wait its the same protocol as the rest.....!
Back to the Rebel 2m thread..............
Old 08-26-2023, 11:20 AM
  #705
JSF-TC
JSF-TC's Avatar
Deleted
Old 08-29-2023, 10:35 AM
  #706
model1258
Questions about plumbing of tank? Tank is long and has baffle in middle 1inch hole in middle four small holes around outside for fuel to get in both baffles. So what do you do just plumb it so clunk stays in front baffle? Also do I use the felt clunk supplied the new jet at came with a bigger one in picture?
Old 08-29-2023, 10:38 AM
  #707
model1258
I have two felt clunks because the small one came with the Carf tank and big one came with the new jetcat.
Old 08-29-2023, 03:40 PM
  #708
model1258
Ok, Got the tank all figured out found info on SMCHARG rebel max Build!!
Skunkwrks (08-30-2023)
Old 08-29-2023, 08:59 PM
  #709
Dave Wilshere
I use the Big one JetCat supply in my Fuel containers!
Old 08-30-2023, 04:43 AM
  #710
model1258
Do you use the small felt clunk the one carf supplies in your tanks, Dave?
Old 08-30-2023, 04:48 AM
  #711
model1258
Is this a new style of fuel pump,I haven’t seen any pictures of these?
Old 08-30-2023, 11:24 AM
  #712
Skunkwrks
Skunkwrks's Avatar
The felts pick-ups are better as they reduce the air drawn into the Map .
Think of it as a sponge so when fuel as away from it , there is fuel in the felt pickup.
Changed my Pro from metal pickup to felt and had a lot less air in the map tank.
Old 08-30-2023, 03:45 PM
  #713
model1258
Well,The felt clunk does make sense.
Old 08-31-2023, 11:27 AM
  #714
Skunkwrks
Skunkwrks's Avatar
With my 240 I drilled out the inside diameter to get more fuel; it has made a huge difference in not picking up air into the fuel stream.
Just compare the Swiwin 14o weight to the 166Munts, and it's only 165 grams heavier, and one of my fellow Jet guys is running his with a 140 with no issues . It can be very fast, but that's what the throttle is for.
I was going to use the CMjet tank but will use the lighter-weight Carf tank, yours looks good.
Old 08-31-2023, 01:19 PM
  #715
model1258
The tank and pipe are made very nice.The tank also has very nice fitting.
Old 08-31-2023, 08:10 PM
  #716
Skunkwrks
Skunkwrks's Avatar
Just was my friend Rebel, like you said, it fits great and is deceivingly significant at 3.6 liters.
Old 08-31-2023, 08:55 PM
  #717
Dave Wilshere
[QUOTE=model1258;12781864]Do you use the small felt clunk the one carf supplies in your tanks, Dave?[/QUOTE
i actually use a clunk we had made in the U.K., same as CARF one, but bigger hole. If you are careful you can drill out the Tillotson one supplied, do it in steps to 3mm. Then it will work perfectly with the new Brushless pump on the P-130
Old 08-31-2023, 08:57 PM
  #718
Dave Wilshere
More than a year ago!
Old 09-01-2023, 11:30 AM
  #719
model1258
Well,Got all the wing wires and retracts working properly, got the turbine and pipe put in and fuel pump and UAT. Ready to start putting all together.
Does the pipe to turbine look about right?
Old 09-01-2023, 12:16 PM
  #720
Dave Wilshere
There should be 25mm/1” between the back of the turbine tailcone and start of the steel tube…
Old 09-01-2023, 12:51 PM
  #721
model1258
Thanks Dave, I tried mounting the turbine and pipe as close as I could by looking at your Pictures of your builds and mine is very close to that 1'' you said.
Old 09-01-2023, 03:02 PM
  #722
model1258
Thought I would show a few pix of the stock Carf pipe.
Skunkwrks (09-02-2023)
Old 09-03-2023, 06:22 AM
  #723
Canadian Man
Canadian Man's Avatar
The Rebel Begins!
The following 4 users liked this post by Canadian Man:
danny-p47 (09-03-2023), paulhat (09-04-2023), RC Rich (09-06-2023), Skunkwrks (09-03-2023)
Old 09-06-2023, 06:49 AM
  #724
Canadian Man
Video #2.
The following 3 users liked this post by Canadian Man:
danny-p47 (09-07-2023), gpman (09-06-2023), paulhat (09-07-2023)
Old 09-09-2023, 05:33 AM
  #725
model1258
Ok, Is it alright to mount Gyro on that surface, is it flat and parallel enough, should I put 1/16 piece plywood under Orange surface to strengthen it up?
