Welcome to Club SAITO !
Old 02-21-2009, 02:48 PM
  #13926
Ram Jet
Ram Jet's Avatar
Default RE: Welcome to Club SAITO !
You are a very lucky man to have owned such a car. My first ride in a sports car was in a black Austin Healy 3000 with the electric overdrive. We drove to the Watkins Glen Grand Prix with my girlfriend and her brother driving. I sat on the transmission hump. Right up there with my ride in a Stearmna PT-17.
Bill
Old 02-21-2009, 02:50 PM
  #13927
Birman
Thanks Hobbsy.
Old 02-21-2009, 02:53 PM
  #13928
RC Specialties
Larry,
The 12mm size TurboHeader does have the baffle when used on the .82. It retunes the chamber for the .82 displacement and is not needed on the .91 or 1.00. That is one of the original designs. The attached photo is the latest design.
Jim
Old 02-21-2009, 03:03 PM
  #13929
Birman
Thanks Jim. I just sent you a email, but you just answered my question, so disregard the email. What is the current price for the latest design?
Birman
Old 02-21-2009, 03:20 PM
  #13930
RC Specialties
Larry,
They are advertised under item #483717. They are on sale this month for 15% off.
Jim
Old 02-21-2009, 03:35 PM
  #13931
Birman
Is that 15% of of the price listed at the top of the ad?
Larry
Old 02-21-2009, 04:02 PM
  #13932
RC Specialties
Yes!
Old 02-21-2009, 04:11 PM
  #13933
Birman
Thanks. Offer made.
Old 02-21-2009, 06:13 PM
  #13934
Rudolph Hart
Rudolph Hart's Avatar
Thats not really fair jim all those pictures and dave's comparison shot have eroded my resistance and i'll order three.One each for the 30,62,and 82 please.Don't use credit cards do you use direct debit??
Old 02-21-2009, 06:15 PM
  #13935
Rudolph Hart
Was lucky enough to see a gt40 do some demo laps here..turns your ears and legs to jelly
Old 02-21-2009, 06:32 PM
  #13936
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
OK OF, lets make it even more unfair, comparo picture is of the 2.20 stock muffler and the 2.20 TH. The TH weighs exactly half as much as the stocker.
Old 02-21-2009, 06:33 PM
  #13937
RC Specialties
Old Fart,
I will send you a PM.
Jim
Old 02-22-2009, 03:40 PM
  #13938
Birman
I have to reverse the carb on my Saito 82. Is there anything special I need to know about doing that so that I don't screw it up?
Birman
Old 02-22-2009, 03:52 PM
  #13939
w8ye
My Feedback: (16)
w8ye's Avatar
undo the two screws, swing it out to the left. Twist the carb around, swing back into position. Replace the two screws
  #13940
N1EDM
Nope, there is nothing special to do.
Just back out the screws and flip it over. I had the same question the first time that I reversed the carb on my Saito .56
Bob
Old 02-22-2009, 04:01 PM
  #13941
Birman
Thanks guys. I'll git er dun...
Old 02-22-2009, 07:02 PM
  #13942
RC Specialties
Gentlemen,
I am considering the FG-36 for a new project. Can any users offer any info such as fuel consumption, odd behaviors, etc. I have seen a few post that refer to the tuning being very touchy.
Jim
Old 02-23-2009, 03:03 AM
  #13943
mikea1022
I have a FA-80 that I bought back in '89. Crashed it the same year when the ailerons jammed. I disassembled, cleaned, lubed, and reassembled it and put it in a box. The only apparant damage is the tube going from the carb to the head. I haven't flown anything since then but was thinking of getting back into it. Are parts for this motor still available? This engine had just a few hours on it and I'd really like to get it running again.
Thanks!
Mike
Old 02-23-2009, 05:45 AM
  #13944
Rudolph Hart
I'll bet there's heaps of spares out there,good luck with it mate.
Old 02-23-2009, 05:49 AM
  #13945
Rudolph Hart
Apart from shaving a kilo off the engine weight jim can you be a bit more descripitve as to your honourable intentions with the fg36??
Old 02-23-2009, 06:16 AM
  #13946
RC Specialties
OF,
I plan to use it in a giant Super Sportster.
Jim
Old 02-23-2009, 07:15 AM
  #13947
mike109
mike109's Avatar
G'day OF. Well I ran the Saito FA90TS today. And does it sound nice? I put one tank through at about half throttle well rich at about 4000rpm then the next at 5000. I flick started it first flick both times. I have mounted it in my ARF Kadet Senior with the cowl off. It is not the easiest engine to set up as the carby is hidden behind the engine and very close to the firewall. It is also right in the centre line of the tank (which is good) but you can not run a straight push rod to it as a result. The standard flex exhausts are rather large and cumbersome and I think I will look for a better solution from Keleo or Turbo Header. The stock ones will be fine for the moment though. Hope the weather is OK on the weekend so I can get some air under the wings and see how it runs in the air. By its third run (which had to be short as some one turned up) it was running without glow power but still quite rich. In the first two runs it would drop a cylinder if I pulled the glow drivers off. Mike
Old 02-23-2009, 11:51 AM
  #13948
McCrash
I'm sure someone has answered this before but I'm looking for a straight pipe for my Saito .91 will the SAI170374 or the ASI100T174 fit? thanks
Old 02-23-2009, 12:05 PM
  #13949
McCrash
Oops, I miss typed the Saito part number for the "muffler with pressure nipple" it is SAI100T174 or SAI170R374, I sure wish Horizon would add more technical info to parts, sizes, length and etc. Thanks
Old 02-23-2009, 08:08 PM
  #13950
wjbender
I need suggestons on what size fuel tank to use for a Saito 82. I was thinking a 10 oz would be about right assuming flying at about 1/2 throttle most of the time. I want about 10 min flight time and enough safety time for on the ground warm up and taxi to flight line etc.
