Welcome to Club SAITO !
Old 08-12-2008, 09:25 PM
  #11726
andy530
Default RE: Welcome to Club SAITO !
where do i get parts for a saito fa-50 engine what kind of glow plug should i use from towerhobbies
Old 08-12-2008, 09:27 PM
  #11727
Mikecam
Hi again gentleman. I'm getting close to breaking in my new 125 and I noticed some play (in and out) of the throttle barrel. I've read lots about Saito's having a spring in there engines and remember that the 125 does not have one. Should I be concerned with the play? Thanks
Old 08-12-2008, 09:37 PM
  #11728
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
NO, none of my latest Saitos have the spring and none is needed.
Old 08-12-2008, 09:43 PM
  #11729
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: andy530
Use the OS "F" plug from Tower Hobbies
Get Parts for your Saito 50 from www.horizonhobby.com Many of the parts in a Saito 50 are common with a Saito 56
Old 08-12-2008, 09:57 PM
  #11730
Mikecam
Thanks Hobbsy, I feel much better. Tomorrow I start my first ever Saito, I'm starting to get rather emotional.
Old 08-13-2008, 12:43 AM
  #11731
romonte
For Saito 125;3 blade 14x7 is ok.?.
Thank
Old 08-13-2008, 04:31 AM
  #11732
Rudolph Hart
Rudolph Hart's Avatar
Good luck with your saito mikecam
I've seen bubbles coming back up the fuel line from the refuelling valve occasionally,once again not always,while the engine is running and thought the same.I bypassed it and the fuel filter too..same problem.It's the angle on the photo,the main needle is about 5mm away from the bolt head.The engine feels and sounds tight and sweet.Fuel cap problem?
Hobbsy i'd like to see your prop figures for a 62a.I'm running 10% nitro and all synthetic oil.Top rpm i can get with the 13x6 apc is 8500.
rlmcnii i think a soft mount is mandatory when you tune an engine like i do..
Old 08-13-2008, 06:34 AM
  #11733
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I just ran my 2nd .62 a few minutes ago.
Fuel===WildCat 15% with 18% all synthetic
Plug===Fox Miracle
Stock exhaust
Bolly 12.5x6==10,350 home grown for you OF
Graupner 12.5x6==9.950
APC 12x7=====9,950
The HS needle is about 1.75 turns out from bottomed out and will barely run at 3 turns out.
Pics with Graupner 12x7 and WildCat 15%/18% 80/20 lubd.
ID:	1010469   Click image for larger version
ID:	1010470   Click image for larger version
Old 08-13-2008, 07:46 AM
  #11734
BobMaine
ORIGINAL: Hobbsy
I have a new Saito 1.00 and it has a spring in the throttle arm area. When I go to turn the LSNV the plastic arm will move in, the rpms will change and sometime the engine stalls. Is this the spring you say is not needed?
Bob
Old 08-13-2008, 07:56 AM
  #11735
sodbuster 1
sodbuster 1's Avatar
What's the best prop 1.00 combo for Sport/Aerobatic flying as far as performance is concerned?
Am installing it in an 80" Goldberg Decathlon
Old 08-13-2008, 09:58 AM
  #11736
w8ye
My Feedback: (16)
w8ye's Avatar
14-8
Old 08-13-2008, 10:37 AM
  #11737
sodbuster 1
APC my best bet?
Old 08-13-2008, 11:30 AM
  #11738
w8ye
My Feedback: (16)
w8ye's Avatar
Yes,
But actually there are a lot of variables in propellers and personal openions and perceptions often effect propeller choice.
If you only come across a Master Air Screw Black 14-8 it will be OK.
The Windsor Scimitar is an excellent prop as well as others
Generally for sport use the JFZ Zinger wood props do not seem to run as well on the ground
Top Flite wood props do not pullas well on the ground as do APC props
Wood props do not idle as well because they weigh less
Old 08-13-2008, 01:15 PM
  #11739
andy530
what is the difference between a wood propleller and a plastic propeller? what is better? also i have a saito fa 50 what size prop should i use it has an 11x7 prop on it. it is a trainer plane
Old 08-13-2008, 01:41 PM
  #11740
w8ye
My Feedback: (16)
w8ye's Avatar
There's not necessarily anything wrong with the prop you have on your plane.
The plastic props are more resistant to damage from ground strikes or hanger rash
The engine will idle lower with a plastic prop because it is heavier and offers more flywheel action
Plastic props are thinner and the engine turns up more rpm on the ground
Old 08-13-2008, 03:55 PM
  #11741
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That's the one Bob, my 1.00 may very well have one if yours does. My 2.20 and 1.25 do not have them. I'll check the 1.15.
Old 08-13-2008, 04:09 PM
  #11742
BobMaine
ORIGINAL: Hobbsy
Interesting... I'm having a heck of a time getting this engine to smooth out, looking for all the things to try that I can find. Maybe I need a new spring!
Old 08-13-2008, 04:47 PM
  #11743
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Bob, where is it running rough, idle, mid or at full throttle. Normally a rough Saito or a thristy one is set too rich. A Saito will run so rich its scary then folks are afraid to lean it enough thinking they're leaning it too much
Old 08-13-2008, 04:55 PM
  #11744
BobMaine
ORIGINAL: Hobbsy
It is roughest at mid throttle. The whole airplane shakes so bad you can't hear the engine running.
That would be me about leaning. I keep hearing about "running it too lean" and the consequences that could happen. I'll give it another go this weekend will try it leaner.
Old 08-13-2008, 05:02 PM
  #11745
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Bob, you don't need to worry too much about getting it too lean in the midrange because it will just quit. Peak the HS needle before doing any midrange leaning. That will help a lot. Peak it very slowly, sort of sneak up on it until it begins to slow slightly from being a little lean, then go back maybe one click on the rich side of the peak.
Old 08-13-2008, 05:37 PM
  #11746
blw
blw's Avatar
Some Saitos have a null or dead spot before you get it lean enough. My .72 fooled me until I went ahead and leaned it out another full turn or so. It would start to sag but wasn't putting out the power it should, so I kept on going until I got past that null spot.
Old 08-13-2008, 06:07 PM
  #11747
Mikecam
I hate to ask a stupid question but here goes. I'm getting ready to fire up my 125. Manual says to add some ARO before first start up. I have read that dexron atf oil is good for that purpose. I have dexron lll, will that work or should i go buy regular dexron. Thanks
Old 08-13-2008, 07:33 PM
  #11748
NM2K
My Feedback: (14)
I don't think it will matter at all. The point is to have some kind of lubrication in the bearings and lower connecting rod during the first few rotations of the engine. What you have should work just fine.
Just don't be tempted to use WD40. It isn't a lubricant, but lots of folks think it is and then try to use it as one. Big mistake. You may know this, but others do not.
Ed Cregger
Old 08-13-2008, 07:52 PM
  #11749
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Mike, there is already a black grease in the crankcase, Pic. #1 shows it undisturbed, pic. #2 shows it working its way out with the oil.
ID:	1010963   Click image for larger version
Old 08-13-2008, 08:02 PM
  #11750
andy530
how do i take of and land can i do this in the grass. i know this is not about engines but its about what the engine goes on. i have a trainer airplane with ab out a 3 1/2 ft wingspan
