Welcome to Club SAITO !
Old 01-16-2008, 08:48 PM
  #9651
RPMcK
RPMcK's Avatar
Default RE: Welcome to Club SAITO !
Well now I'd say that sucks!! :-) I see your point. Would probably suck air/oil or what ever by the ring/piston to breath. That being the case it makes you wonder why Saito didn't put two vent nipples in to start with. But at least it's nice that there is one available for field instalation.
Old 01-16-2008, 09:39 PM
  #9652
colecaz
Here's how I did my 72.. The tubing is 5/32 ID I found at the LHS and the clamp is for normal fuel line, stretched to work over the 5/32. The larger tubing slips past the barbs on the nipple and over the hex base. Total length about 8" and I didn't notice any degredation when I put it on like I did with 3/32.
Old 01-16-2008, 10:44 PM
  #9653
We3R/C
Good Answer w8ye!,Now which one is "intake" and which one is "Out"? Does it mattter?
Old 01-16-2008, 10:47 PM
  #9654
the pope
ORIGINAL: N1EDM
I had a thought about this crankcase venting, and the tubing length. I imagine that there's a maximum length because the waste oil will form a 'plug' in a hose that is too long. There is a positive and a negative pressure on that nipple caused by the up-down motion of the underside of the piston. That plug of oil will flow back and forth in a too-long hose because there is only so much volume in the crankcase to push the plug out.
How about if we put a short piece of, say, 3/32" hole over the breather nipple (because that's the size that the nipple was designed for), then sleeve that piece with a larger diameter sleeve to let oil flow out, and air flow in simultaneously
I don't know if I made any sense with my description or not...
Just a thought...
Bob
I dont know if this would work or not but what if you put a tee in the line say 2 '' from the the vent and then put the tube facing up so it could suck air in that way while the oil flows down the long main fuel tubing. cheers the pope
Old 01-17-2008, 02:30 AM
  #9655
weswanson
It does. Thank you Bob. I thought it was just a drain not realizing it pulsed as the engine ran.
Walt
Old 01-17-2008, 10:21 AM
  #9656
jerrya
What size Saito engine mount do I need for my Saito FA 82 engine. Would like to use a one piece aluminum mount but I can't figure out the size according to Saito's lettering!
Old 01-17-2008, 10:35 AM
  #9657
w8ye
My Feedback: (16)
w8ye's Avatar
The 82 is 35mm or a little over 1 3/8 " across the crankcase at the mounting lugs
You will need a mount that has that much distance between the rails
I use the Great Planes Adjustable 40 size mount
Old 01-17-2008, 11:00 AM
  #9658
RPMcK
RPMcK's Avatar
Got a question for some of you experienced Saito owners. I just bought a new Saito 180. The manual recommends using a fuel with 10% to 15% Nitro and 20% oil. Where I live everything comes in by wagon train so I really need to know what I'm buying when I order something. I haven't been able to find any with 20% oil except one with 30% nitro. What do you guys use? I want to be sure I break this new engine properly. Any suggestions.
Old 01-17-2008, 11:09 AM
  #9659
colecaz
Powermaster makes a fuel called YS 20/20 that also is sometimes labelled YS/Saito
http://www.powermasterfuels.com/products/Pattern.html
I used Cool Power 15%, which has 17% synthetic, and added a few ounces of Sig Klotz 2 cycle oil to bring it to about 22% for breaking in a 72.
Old 01-17-2008, 12:33 PM
  #9660
rlmcnii
jerrya,
http://www.horizonhobby.com/Products...ProdID=SAI5095
This is it
Old 01-17-2008, 12:51 PM
  #9661
w8ye
My Feedback: (16)
w8ye's Avatar
Order regular gallon of 15% nitro and 17% oil fuel and put a 2oz bottle of castor oil in it from from THE store.
UPS charges outrageous prices for shipping fuel.
Better yet, just order the least you can (to get you by) and the next time you go to Billings, buy a case of fuel and a bottle of Sig castor oil.
You should be able to get what you want in Billings.
Old 01-17-2008, 01:04 PM
  #9662
w8ye
My Feedback: (16)
w8ye's Avatar
There are three model airplane Hobby shops in Billings. A couple are nice nationally known ones. You should be able to get whatever you want there.
Abell Hobbies & Mfg
1125 Monad Road
Billings, MT 59101
(406)259-4882
http://www.abellrc.com
Central Hobbies
1401 Central
Billings, MT 59102
(406)259-9004
http://www.centralhobbies.com
Heliproz, Inc
1728 Lampman Drive Ste E
Billings, MT 59102
(406)245-8480
Old 01-17-2008, 01:27 PM
  #9663
RPMcK
RPMcK's Avatar
Thanks for the response guys. I've done business with Central Hobbies in Billings. As you say, w8ye, it makes more 'cents ;-) to drive to Billings (+ or - 100 miles) and buy a case of gallons than pay shipping by UPS. And with the good information you've given me I'll know what to get when I get there. And the wife usually drags me up there a couple time a month anyway so the freight on the fuel will be basically free. Can't beat that. Thanks agaion and have a great day!!
Old 01-17-2008, 02:44 PM
  #9664
starkms
I have the FA-62 and I ran a short tube from the breather into the carburetor so it will suck in the oil, and it will go through the engine again. [8D] Most of the extra oil goes out the exhaust, there is a little that ends up on the outside of the engine, not enough to drip into the cowl. I am still breaking the engine in so it has been running extra rich. I haven't had any transition or dead stick problems with it yet and it keeps the outside of the plane much cleaner than the 2c! I read somewhere in this thread about drilling and tapping the intake and installing a nipple to run the breather tube to. This will keep the oil from splashing out of the carburetor when you are at idle.
Old 01-17-2008, 02:49 PM
  #9665
colecaz
Starkms
How did you secure the end of the tube at the carb??
Old 01-17-2008, 03:54 PM
  #9666
starkms
I tie wrapped an aluminum tube to the inverted engine mount. I connected it to the breather with a short piece of fuel tubing and another short piece to just above the carb barrel to minimize oil splash out at low throttle settings.
Old 01-17-2008, 04:51 PM
  #9667
blw
blw's Avatar
Ron,
The fuel will last just about forever if you keep the jugs in the box, and in a temp controlled place out of sunlight. I buy mine that way and it sometimes takes a while to use up all that I have. You could buy a case or two, and not worry over the winter.
Old 01-17-2008, 05:49 PM
  #9668
RPMcK
RPMcK's Avatar
I would definately want to buy enough fuel at a time to make a 200 mile round trip worth while. got any idea how long a gallon of fuel would feed a l80 in normal operation?
Old 01-17-2008, 06:06 PM
  #9669
rlmcnii
http://www.horizonhobby.com/Articles...ArticleID=1161
This is a listing of Saito letter codes.
Old 01-17-2008, 06:43 PM
  #9670
okelly
Hello All Saito Experts,
Can anyone tell me on which end of the manifold the aluminum gakst geos?
Old 01-17-2008, 07:15 PM
  #9671
Ken6PPC
The side of the intake manifold closest to the cylinder gets the aluminum gasket.
Old 01-17-2008, 07:20 PM
  #9672
w8ye
My Feedback: (16)
w8ye's Avatar
Slide the aluminum gasket up against the stop and the the viton o-ring
Old 01-17-2008, 07:53 PM
  #9673
Ken6PPC
I have a question. Is there a top and bottom for a Saito piston ring? My replacement ring looks the same to me, but I know some rings are designed to only be installed in one direction.
Old 01-17-2008, 09:04 PM
  #9674
Michaelh
ORIGINAL: Ron Mckinley
Im getting 8 12-15min flights off a gallon.
This is on a 1100 sq in 11.5pound model. Wingloading is roughly 23oz ,some 3d but mostly scale aerobatics.
Old 01-17-2008, 09:35 PM
  #9675
We3R/C
Hi Guys I have a Question regarding my Saito 82.I would like to put and extension on my exhaust, so as not to cover the top of my wing with residue.Will Reg. clear tube(such as found at plumbing store) work? Will this ext. affect performance? Thanks.Mike
