Reload this Page >
FokkeRC 1/5 Spitfire MKIX build log
Old 12-23-2020, 07:47 AM
  #51
Wyoturbine
Wyoturbine's Avatar
Originally Posted by FlyerInOKC
Have you checked with Dave Brown? They do custom spinners if a stock spinner won't work and they do have a 5" X 5" spinner.
https://www.dbproducts.com/index2.htm
I looked at his site this morning, I’ll give him a call after the holidays and see what he can do,
Thanks!
Old 12-23-2020, 11:16 AM
  #52
Lifer
Lifer's Avatar
I checked the Top Flite Giant P-40, and it's 5.5" and of course not a parabolic.
Old 12-24-2020, 04:41 AM
  #53
Wyoturbine
Wyoturbine's Avatar
Thanks for checking John! I looked into Dave brown a bit more, they have a spinner that should fit the bill, 5”x5” and looks to be right.
when it comes in I’ll post photos outling the cowling. Here’s stock photo, the lines/shape look much closer.
Old 12-24-2020, 06:50 AM
  #54
FlyerInOKC
FlyerInOKC's Avatar
That is good news!
Old 12-24-2020, 06:57 AM
  #55
Wyoturbine
Wyoturbine's Avatar
That is good news!
Yes! Thanks for pointing in that direction. This guy should work.
Old 12-26-2020, 05:30 AM
  #56
Wyoturbine
Wyoturbine's Avatar
Jose at Fliteskin Aeroscale sent me an email, they carry a 5” aluminum spinner as well, it’s the same spinner they use on their DH-103 hornet and sea hornet.
So I’ve got options! I’ll check out how the Dave Brown looks and make a decision. I’ll also see if Jose can send me some photos of just the spinner.
This is best one I can find of it on their site. Lines look good but I’d like to get a closer look.
Old 12-26-2020, 05:30 PM
  #57
ForcesR
The attached link shows the spinners for the DH-103 that are not attached to the engine which may assist you in deciding which spinner to purchase.
https://www.rcgroups.com/forums/show...span-%28Kit%29
Old 12-27-2020, 04:08 AM
  #58
Wyoturbine
Wyoturbine's Avatar
Thanks Forces! Jose at Fliteskin sent me photos as well(He is awesome with answering questions and helping a guy out), He’ll drill and tap the side screws but cannot cut spinners. So I’ll need to find someone who can if I decide to go with his.
Old 12-27-2020, 06:21 AM
  #59
Lifer
Lifer's Avatar
Mike knows a local machinist that can cut your spinner.
Old 12-27-2020, 06:46 AM
  #60
Wyoturbine
Wyoturbine's Avatar
Oh good to know! I’ll give him a shout. Thanks!
Old 01-09-2021, 05:15 AM
  #61
Takashi Matsui
Hello, I am also making the same aircraft now. The canopy is much smaller than the Fokkerc drawing and the Montforton drawing. Isn't your canopy small?
  #62
Takashi Matsui
Old 01-09-2021, 05:47 AM
  #63
fokke
fokke's Avatar
Takashi Matsui, as I wrote you on PM , no problem with the size of the canopy !
Before to cut the canopy you have to cover the fuselage with balsa. Before to cut you have to think did you make somewhere mistae and then to cut and write that all is wrong !
This model we produce from several years , only you find mistakes in the canopy..........
Old 01-09-2021, 08:30 AM
  #64
Wyoturbine
Wyoturbine's Avatar
Hi Takashi, I just got home and grabbed mine out of the box, it matches up perfectly, what are the measurements; length and width of yours?
Old 01-09-2021, 08:44 AM
  #65
Wyoturbine
Wyoturbine's Avatar
I just got home after a few busy weeks at work, my Dave Brown spinner arrived, however I think I’m going to return it and go with Fliteskin’s. The length and width are correct but it doesn’t have the scale shape I’m looking for. It necks down too much toward the tip where as the mkix had a bit more of a bulbous shaped nose toward the tip of the cone.
Old 01-09-2021, 11:45 AM
  #66
FlyerInOKC
FlyerInOKC's Avatar
The onle on the plan has a more blunt end probably for the fastener the tip should be as pointed as possible like the full size airplane.
Old 01-09-2021, 12:32 PM
  #67
Wyoturbine
Wyoturbine's Avatar
My post may have been hard to understand, apologize for that. I’m mainly speaking to the conicle shape as it necks down toward the tip.
Rumen’s plans are spot on as to this particular spinner.(Potter type) There were a few alternate spinner nose caps they used on the mkix, Rumen’s plans used a recessed cap version or potter from I can tell.
Old 01-10-2021, 05:17 AM
  #68
Wyoturbine
Wyoturbine's Avatar
I’m going to go with Fliteskin Aeroscale’s spinner, it’s the correct size and most importantly to me it’s the correct shape. Jose at Fliteskin is great to work with and will drill and tap it for the securing screws. I haven’t had a lot of time to build as of late but will fire up the build again shortly.
Old 01-10-2021, 07:51 AM
  #69
FlyerInOKC
FlyerInOKC's Avatar
Now that is more like it! What holds the cone on?
Old 01-10-2021, 08:50 AM
  #70
Lifer
Lifer's Avatar
The centering shaft on the DLE 55 is threaded to accept spinner mounting screws, as are most gassers.
Old 01-10-2021, 09:45 AM
  #71
Wyoturbine
Wyoturbine's Avatar
It’ll come drilled and tapped for side mounting screws into the baseplate.
Old 01-10-2021, 10:26 AM
  #72
FlyerInOKC
FlyerInOKC's Avatar
It should look fantastic!
Old 01-10-2021, 11:05 AM
  #73
spitfire66
spitfire66's Avatar
The fliteskin spinner looks great and has the perfect shape. I’m looking forward to seeing it with the cowl.
Old 01-10-2021, 03:02 PM
  #74
Wyoturbine
Wyoturbine's Avatar
Me too! I’ll post a pic as soon as I get it in. I think it’s worth the trouble of getting it cut for sure.
Old 01-12-2021, 12:29 PM
  #75
benoit64
benoit64's Avatar
Hi everyone ! your post is very interesting, i also build a fokkerc spitfire, a 1/4 scale Mk XIV. It's been over a year since I started it, but I work a lot, so not too much time for the spit. I put you some pictures!
Everything is made by me, the trains the spinner, the karmans .....the cockpit, dashboard, seat, instruments ...
ID:	2269095Click image for larger version
[URL=https://www.casimages.com/i/210112092936531822.jpg.html]Click image for larger version
ID:	2269098[/URClick image for larger version
