Reload this Page >
BIG A-5 Vigilante build
Old 06-19-2017, 07:09 PM
  #451
jofunk
I took the plane outside and rolled a coat of 2K primer on almost everything. Now I can see all the lumps, bumps, and ridges. I drilled the holes for the stab retainer pins. I finished sanding the plug for the nose camera glass.
ID:	2220894   Click image for larger version
ID:	2220895   Click image for larger version
ID:	2220896   Click image for larger version
ID:	2220897   Click image for larger version
ID:	2220898   Click image for larger version
Old 06-28-2017, 09:28 AM
  #452
turbofixer
Will you be adding the strake on the wing leading edge to the front of the intake? the late block C had this
Old 07-03-2017, 02:44 PM
  #453
jofunk
Hi TF, The plane will not have the strakes. Just one less thing to build for now........ I started filling and sanding a few things. I also added a few details. There is a hump above the elevons and there is a wing folding mechanism at the fold hinge line. I turned the balsa in a drill to make the shape and then sawed it in half to glue it on the top and bottom of the wing. Everything will get some more sanding filling shaping and glass.
ID:	2222799   Click image for larger version
ID:	2222800   Click image for larger version
ID:	2222801   Click image for larger version
ID:	2222802   Click image for larger version
Old 07-03-2017, 05:38 PM
  #454
sc0tt
My Feedback: (61)
sc0tt's Avatar
Should be ready for JOK next week right Joe? - like my big A-6, lol. See you there...Scott
Old 07-04-2017, 10:53 AM
  #455
jofunk
Yes Scott, We can park them next to each other. Thanks for calling for me in Winamac the other week. (and carrying)
Old 07-08-2017, 03:08 PM
  #456
jofunk
I glassed over the the little added details. they will get sanded down and primed.
ID:	2223695   Click image for larger version
Old 07-12-2017, 07:11 PM
  #457
jofunk
I worked on securing the main hatch with a few tongues and a home made slider pin. I also flipped the fuse and cut out the engine access hatch. Two recessed screws will hole the bottom hatch. Everything got shimmed and glassed or resined. Now it is off to JOK with the Panther and a Boomerang
ID:	2224189   Click image for larger version
ID:	2224190   Click image for larger version
ID:	2224191   Click image for larger version
ID:	2224192   Click image for larger version
ID:	2224193   Click image for larger version
ID:	2224194   Click image for larger version
ID:	2224195   Click image for larger version
Old 08-08-2017, 08:22 PM
  #458
jofunk
The bottom of the plane and all the hatches and control surfaces got primed. The low spots got a little filler. now everything needs more sanding.
ID:	2227441   Click image for larger version
ID:	2227442   Click image for larger version
Old 08-08-2017, 08:48 PM
  #459
jofunk
BTW In honor of Picasso downtown turning 50 years old today here is my Ziroli P 40 parked in front of it last month.
Old 08-09-2017, 03:59 PM
  #460
turbofixer
That is a lot of small parts for one big jet!
Old 10-18-2017, 04:39 PM
  #461
jofunk
After a bit of a break being busy with summer things, I took the fuse out to start sanding the primer down. After all the sanding Ill spray a coat of primer and then on goes the colors.
ID:	2241595   Click image for larger version
Old 11-05-2017, 08:21 PM
  #462
jofunk
Vladimir and I vacuum formed a few, 3 canopies for the Vigilante. The spray foam under the hatch worked. The plug did not crush. I also made a few of the camera housings for under the nose. One of the shots we let the plastic heat too long and had too much sag. Some areas had a fold of material. I also think the plastic we are using is too thick and we can be using the same amount for much bigger parts. It is a bit of an art and takes practice to get perfect parts. I also hogged out the foam from under the canopy.
ID:	2243794   Click image for larger version
ID:	2243795   Click image for larger version
ID:	2243796   Click image for larger version
ID:	2243797   Click image for larger version
ID:	2243798   Click image for larger version
Old 11-12-2017, 08:21 PM
  #463
jofunk
I started cutting some G 10 for the spoilerons And the hinges for them. I smoked a band saw blade cutting the stuff. The solution was a wet tile saw. It cut very fast with no dust. It will also work to grind shapes out of the g 10.
ID:	2244874   Click image for larger version
ID:	2244875   Click image for larger version
ID:	2244876   Click image for larger version
Old 01-24-2018, 09:11 PM
  #464
jofunk
Just waiting on some bearable weather to go outside and finish sanding the primer. In the meantime both spoilerons got hinged, glued and screwed into place along with some filler to feather them in. Its been a slow go over the winter.
ID:	2252137   Click image for larger version
ID:	2252138   Click image for larger version
ID:	2252139   Click image for larger version
Old 03-18-2018, 08:06 AM
  #465
jofunk
I got one nice day so I sanded a little more on the fuse. Just waiting for a good day to spray. I glued some wood under the canopy so it wouldn't shift side to side. Some 3/4" neo magnets will hold down the canopy. They got glued and glassed down. I sunk some neo magnets in the nose to hold some covers for the nose bolts . Some blocks got pulled in and glued to screw the turkey feathers into. I started grinding a new foam plug for a different shaped fuel tank.The camera ports got blacked out and the cameras installed. The turkey feathers got glued onto some ply disks. I ll post some pix late.r
Old 03-18-2018, 10:42 AM
  #466
pilot43
pilot43's Avatar
I like Vigilant from my childhood, I really like your work and I sincerely wish that this model pleased everyone with its flight.
Old 03-18-2018, 06:05 PM
  #467
jofunk
Old 03-18-2018, 06:13 PM
  #468
jofunk
Old 03-18-2018, 06:27 PM
  #469
jofunk
Thank you Pilot43................Sorry about the gigantic pictures. Does anyone know what to change to post smaller pictures.
Old 03-18-2018, 10:02 PM
  #470
SHANEC
SHANEC's Avatar
Looking good!!!!
Old 03-20-2018, 09:27 AM
  #471
turbofixer
Nice work..I like the big pictures..Good for detail stuff
Old 03-21-2018, 09:10 PM
  #472
jofunk
Thanks TF........There is a long pitot tube on the full scale nose. I stretched a piece of a balloon over the nose and laid up some glass cloth to make a pocket. I can build a tube off of the pocket and maybe stick it on the nose for static display. I hope the duct tape holds.
Old 03-22-2018, 07:47 PM
  #473
jofunk
The tape held. I trimmed the edges and sunk a magnet in the glass and in the nose to make the pitot tube quickly removable. the magnet in the nose makes for a good temp nut and bolt holder. The tube is a piece of CF rod out of an old umbrella. Then everything got lined up and glued.
Old 03-25-2018, 09:26 PM
  #474
jofunk
There was a bit of a gap around the canopy/ hatch so I started fill it with bondo. Parchment paper is the barrier and electrical tape kept the bondo off the outside of the fuse. I pulled the hatch when it started getting firm and trimmed the blobs down and peeled the excess off to neaten things up.
Old 03-31-2018, 02:22 PM
  #475
jofunk
OMG becky some colors. I am going to hold off on putting the glass in so I am silvering out the canopy. I taped off where the glass would be and put down some 1/32 tape to simulate a hatch line. I shot some gray to see what the top color looks like.......... Happy Easter everyone.
