Reload this Page >
BIG A-5 Vigilante build
Old 09-03-2016, 08:55 AM
  #351
jofunk
The stringers behind the plate got doubled up since they were cut a little short. I also started to sheet the area. I will soon install the nose gear and get some glass on the front end and in the intakes.
ID:	2179394   Click image for larger version
Old 09-05-2016, 06:26 PM
  #352
jofunk
I finished sheeting the bottom and sides. The larger flat pieces got combo glued, CA and urethane.
ID:	2179799   Click image for larger version
ID:	2179800   Click image for larger version
Old 09-06-2016, 09:16 PM
  #353
jofunk
I removed what was needed to roughly install the nose gear. It will take some tweaking to get Vladimir's nose strut ornaments in the correct position. Picture one, if you don't have the tool to make the cut sometimes you have to make the tool.
ID:	2180066   Click image for larger version
ID:	2180067   Click image for larger version
ID:	2180068   Click image for larger version
ID:	2180069   Click image for larger version
Old 09-07-2016, 02:05 PM
  #354
turbofixer
Super clean!
Old 09-21-2016, 12:41 PM
  #355
jofunk
I got the glass cloth out to start glassing and hardening the intakes etc. I put some wax paper down over the door area. I will glass over the wax paper and have a shell of the area. If the gear doors don't survive getting cut out, I will have an extra set.
ID:	2182394   Click image for larger version
Old 09-25-2016, 04:58 PM
  #356
jofunk
Here is a better shot of the lay up and the tub peeled off the fuse. If I need doors I can cut them out of this.
ID:	2182839   Click image for larger version
Old 09-28-2016, 06:33 PM
  #357
jofunk
I sawed out enough door area to fit the retract back in. Another door will open over the wheel well. I will save the wood doors and see what works.
ID:	2183285   Click image for larger version
ID:	2183286   Click image for larger version
ID:	2183287   Click image for larger version
Old 09-30-2016, 06:06 AM
  #358
ps2727
Joe
that looks great!
you are doing a nice job
paul
Old 09-30-2016, 01:22 PM
  #359
turbofixer
Looks great!..nothin like cutting into your fresh work
Old 10-08-2016, 04:40 PM
  #360
jofunk
I cut all 6 doors out and got the gear mounted back in. Everything retracts OK and nothing seems to be sticking out.
ID:	2185021   Click image for larger version
ID:	2185022   Click image for larger version
ID:	2185023   Click image for larger version
ID:	2185024   Click image for larger version
ID:	2185025   Click image for larger version
Old 10-10-2016, 10:58 AM
  #361
turbofixer
Outstanding...that looks great...Humm wonder what a scaled down set of gear would cost me..they are pure art work
Old 10-11-2016, 06:59 PM
  #362
jofunk
Hi TF,
I think the landing gear are a one off like the plane will be. Vladimir appreciates your kind words and interest..................... With that said Vladimir wanted to come over and see the airframe sitting on his gear. We took it off the table, flipped it over and plugged everything in. It seems to be sitting at a good angle so the nose gear mount will go in where I figured. I snapped a few pictures with Vladimir in them for scale.
ID:	2185433   Click image for larger version
ID:	2185434   Click image for larger version
ID:	2185435   Click image for larger version
ID:	2185436   Click image for larger version
ID:	2185437   Click image for larger version
Old 10-11-2016, 07:03 PM
  #363
jofunk
Like the Panther I built, it is going to be a flying lumber yard.
Old 10-11-2016, 07:17 PM
  #364
Roger Shipley
My Feedback: (35)
Guys that is some serious gear & gear platform.....WOW ! ! !
Old 10-12-2016, 07:06 PM
  #365
jofunk
I started doubling up the sheeting around the wheel wells to stiffen things. The inside corners of the hoz. stab got cut off on an angle and capped. I cut a piece of lite ply the outline of the camera pod. Pilot G.I. Joe and his radio operator Malibu Ken tried out the cockpit for size.
ID:	2185567   Click image for larger version
ID:	2185568   Click image for larger version
ID:	2185569   Click image for larger version
Old 10-13-2016, 07:41 PM
  #366
jofunk
I cut some maple rails for the nose gear mount, with some ply plates to lock them in.
Old 10-14-2016, 12:54 PM
  #367
turbofixer
Nice and sturdy looking
Old 10-15-2016, 11:30 AM
  #368
jofunk
I cut the sheeting out for the nose gear on the nose. The retract needed to go back a little so i took 1/4" material out to slide it back. I also did a little more work on the camera canoe.
ID:	2185793   Click image for larger version
ID:	2185794   Click image for larger version
ID:	2185795   Click image for larger version
ID:	2185796   Click image for larger version
Old 10-26-2016, 06:19 PM
  #369
jofunk
Not much just some more work on the recon. canoe.
Old 11-03-2016, 06:50 PM
  #370
jofunk
I glued some ply scabs in the bottom of the canoe for the mounting screws. (no pix.) Then some sheeting went on the bottom. I started capping the stringers and edges in the wheel well area for a finished look....... And this is my girlfriends halloween pumpkin. Congratulations to the Chicago cubs, (I'm a Sox fan)
ID:	2188845   Click image for larger version
ID:	2188846   Click image for larger version
ID:	2188847   Click image for larger version
ID:	2188848   Click image for larger version
ID:	2188849   Click image for larger version
Old 11-13-2016, 07:00 PM
  #371
jofunk
I finished capping the wheel well area. I cut and installed some tips for the hoz. stab. I finished sheeting the recon. canoe and cut openings where the cameras go. I flipped the fuse over and bolted on the nose with some wax paper in between to keep from accidentally gluing the nose on. I ran some stringers oner the top. The line looks good.
ID:	2189946   Click image for larger version
ID:	2189947   Click image for larger version
ID:	2189949   Click image for larger version
ID:	2189951   Click image for larger version
ID:	2189952   Click image for larger version
ID:	2189953   Click image for larger version
ID:	2189954   Click image for larger version
Old 11-21-2016, 09:08 PM
  #372
jofunk
Started a little sheeting on the top behind the hatch.
Old 11-25-2016, 10:05 PM
  #373
jofunk
The hatch got more stringers and sheeted. I also laid down some sheeting over the top. The top curve looks good. I need to find more 1/8" sheeting. I may go raid my pal John Roth's balsa stash.
ID:	2191273   Click image for larger version
ID:	2191274   Click image for larger version
Old 12-26-2016, 10:14 PM
  #374
jofunk
All the sheeting is done. A few pain in the butt areas were the compound curves over the canopy and on the turtle deck where the two humps blend. The top is now going to get a bunch of filler and a bunch of sanding and shaping, The very front of the canopy got a foam block. i was going to sheet it but the foam will be a lot easier. The canopy hatch is going to get glassed over and a canopy will get sucked down over it.
ID:	2194453   Click image for larger version
ID:	2194454   Click image for larger version
ID:	2194455   Click image for larger version
ID:	2194456   Click image for larger version
Old 12-27-2016, 05:47 PM
  #375
jofunk
The last pic in the previous post has a bit of an optical illusion. There is not a severe angle change in the top sheeting where the nose separates. It is the top of the right intake curving down and disappearing at the separation point. Here is a bit better pic of the top.
